Filling in and joining corners
fsonnichsen
fsonnichsen
I couldn't find this issue but perhaps don't know how to search for it. I have a common design where screwed connectors accept screws that hold a base as seen in the attachment. I want to add "fillets" to the cylinders such that these join the planar surfaces to attach them and give them strength.
  I would have assumed I could use a tangent/arc construct but 360 does not seem to accept tangents to circles. SO I used the "Conic Curve" shown in one of the cylinders here and extruded it.  This should be fine but is there a better way/tool to do this that I am missing?
  Also -  is the result shown physically "joined" insofar as 3D printing is concerned?
Fritz
jhackney1972
One way to do what I think you desire is by modifying the sketch before extrusion.  I applied my idea to one corner boss.  As far a 3D Printing, make sure the extrusion is set to "Join" the body.  This will allow the feature to print as part of the main body.  Model is attached.
John Hackney, Retired
fsonnichsen
OK-that was a big help. I had actually done the thing with circles but did not remember that the "cut" would work that way. And--yes-on the join. A good technique for a lot of situations.
Fritz
