Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Fillet question
Fillet question
Art5
Message 1 of 13
Fillet question
Art5
I'm working on a stamping die, and I wanted to put some large fillets around the edge of the die, but it will only let me go up to a certain radius before it gives me an error. Can someone help me understand why fusion won't let me put a fillet bigger than 6mm? Ideally, I was hoping to put around a 25mm fillet to help the material flow into the die. As always, any and all help is greatly appreciated.
6mm fillet works6mm fillet works7+ m fillet does not7+ m fillet does not
Replies (12)
Message 2 of 13
jeff_strater
Fillet does have limits to what it can do, primarily driven by the geometry of the edges you are trying to fillet.  Areas of high curvature, and "near tangencies" can all cause fillet to fail.  If you share your design here, we can take a look at it.
Jeff Strater
Engineering Director
Message 3 of 13
Art5
Here ya go
Message 4 of 13
jeff_strater
thanks, @Art5 .  This design looks slightly different than the one in the above image - it looks like we have only part of the pocket:
or, am I missing something?  Thanks.
Jeff Strater
Message 5 of 13
TrippyLighting
Past approximately 6.7 the fillet starts failing because it basically start collapsing.
So you need to make the vertical fillet larger.
Message 6 of 13
Art5
@jeff_strater  We are a prototype shop, the designs are proprietary, so I'm not allowed to share the full die.  I did get permission to share partial designs, so I cut the die in half. I couldn't get the fillet to work on the partial die I provided either.
Message 7 of 13
Art5
The "bottom" of the die is built to part, I can't change the design as it will change the shape of the part.
Where part is must remain the same, I can change my runoff to a certain extent though.Where part is must remain the same, I can change my runoff to a certain extent though.
Message 8 of 13
wmhazzard
Take a look at this file to see if it works for you.
Message 9 of 13
laughingcreek
another possibility if you can't change the geometry near the bottom would trim out some of the surfaces at the top and loft a fillet like surface at the top.  example attached.
Message 10 of 13
Art5
I'm afraid that while this is the size of fillet I was hoping to achieve, this particular solution doesn't quite work for me since the part no longer matches  up with the die in a couple of places.
As you can see, in these locations the die either interferes with the part or doesn't contact itAs you can see, in these locations the die either interferes with the part or doesn't contact it
Message 11 of 13
Art5
@laughingcreek  This does appear to be a viable solution, although I'm not entirely sure how you achieved it.
Message 12 of 13
michallach81
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 13 of 13
Art5
@michallach81 Success!!! This is exactly what I was trying to achieve! Thanks a million!1" Radius Fillet successfully created!1" Radius Fillet successfully created!
