@Anonymous wrote:
... then i try the same shape in solidworks--everythings is OK.
Please Attach your *.sldprt file here.
Did you faithfully recreate the geometry in SolidWorks as native SolidWorks geometry?
Or did you run this geometry through a neutral conversion to open in SolidWorks?
If I Export the geometry as STEP (*.stp) and then Open in Autodesk Inventor Professional (the Autodesk equivalent product to SolidWorks) I am able to Fillet that edge.
If I open the exported STEP in Fusion 360 I am able to Fillet that edge in Fusion.
Well, no file and I am going to bed. I will check back tomorrow for your *.sldprt file with native geometry.
