Fillet between components, is it possible?
6 REPLIES 6
v522
292 Views, 6 Replies
Please see image where (1) a normal Fillet at an edge/corner
Is it possible to create a similar one on (2) but using another component as reference
I am trying to get a bit more contact area for the pillar by the "feet" like the fillet on the top (though its two separate components/Bodies)
it's the same question as here for another product
Labels (1)
6 REPLIES 6
laughingcreek
in reply to: v522
not with the filet tool. the fillet tool only works on an edge in a single body, not between 2 different bodies. you could sweep a profile instead.
g-andresen
in reply to: v522
create a revolve body at cylinder
günther
v522
in reply to: laughingcreek
Thank you @laughingcreek . That should do it
v522
in reply to: g-andresen
Thank you for the example @g-andresen, it really helps
Wish the fillet tool could do this natively as I have many that needs the exact same thing lol
g-andresen
in reply to: v522
Concave fillet needs a single body!
There's a little trick to it.
günther
v522
in reply to: v522
Thank you @g-andresen ! I can do this to all my "feet" in a single shot 🙂
Apparently, multiple ways to do the same and need to be a bit creative!!
