Fillet and Chamfer Tangent Chain tolerance
burzins
burzins
The angle between the normals at the shared edges of the green and blue faces are 0.10° on the left two bodies and 0.11° on the right two bodies.  Fillet with Tangent Chain enabled and selecting only one edge on each body produces what is shown.  Can the Tangent Chain tolerance be modified?
Thank you,
Steve
innovatenate
Autodesk Support
Autodesk Support
I'm not aware of an option or even a hidden file that would allow you to modify this. You can suggest a feature enhancement on the Fusion 360 Ideastation.
Nathan Chandler
Principal Specialist
I apologize for this being a little off topic, but I have a question. How did you create your thread with picture in the text like that? I cannot seem too, other than attaching as a file. Thanks
burzins
Use the Photos button on the toolbar of the Rich Text tab:
