Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fill in cut in 3d contour
4 REPLIES 4
tiemenHYX7W
232 Views, 4 Replies
Hi!    I have a solid part with an overall smooth 3d contour shape. Imported from a step file, so I am missing all the history of the steps to create it. Is there an easy way to fill in the 2 grooves at the top and blend it with the overall contour?  I’ve mostly worked with the Fusion solid commands, and don’t really know where to start looking within the mesh, surface, or form commands.
Any help would be greatly appreciated. Thanks!
4 REPLIES 4
wersy
in reply to: tiemenHYX7W
Maybe you only need to delete the areas of the grooves.
Upload the file with the next post.
tiemenHYX7W
in reply to: wersy
It's an imported file, so i have no separate features to edit.
wersy
Yes it works.
Delete the upper surfaces
And the inside surfaces
tiemenHYX7W
in reply to: wersy
Thanks!! I didn't know you could do that on imported files. I tried it myself too, and works great. Very straightforward.
