Fill a Void Area within a Body
kevinwatts
Message 1 of 13
kevinwatts
I need a method to fill a void/cavity inside a design so that it is solid.
In this case Extrude/Push-Pull does not seem to provide the solution.
The shape inside the body is irregular. Below is a simple illustration of the problem. The internal “Void/Cavity” is caused by the curvature of the outside sphere/shape. Is there a way to fill all the empty space between the interior and exterior walls?
Please and thankyou.
Replies (12)
Message 2 of 13
HughesTooling
Can you make a sketch of one of the D shapes then use revolve join to fill the void. Another thought try selecting the 2 inner surfaces and delete, you'll need to be in the model workspace for it to auto-heal.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @kevinwatts,
Also going off of @HughesTooling idea - if you were to just patch up those holes (or even use a plane if they are perferectly planar with each other), you could then use Boundary Fill in the Create Menu. Boundary Fill is a really neat tool that creates volumes in encapsulated areas. Let me know if you need some help with this method!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 4 of 13
kevinwatts
Thank you Mark & James.
The Boundary Fill sounds like what I need but I have not tried that before. Perhaps there is a tutorial? The voids that I must fill are not as simple as the example that I showed. One of them is between walls/solid faces with no visible way to view from outside the body. I had to use Section analysis to see find it.
I will try the suggestions and report back.
Kevin
Message 5 of 13
PhilProcarioJr
@kevinwatts
Here is the easiest way that I know of for the problem you describe.. Using the Patch Environment select the faces of the internal cavity and delete them. To do this you hold down the control key and left click and hold until the menu comes up. Select the face and repeat while holding the ctrl key to select all the internal faces. Then sticth the surface back together to make it a solid again.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 6 of 13
PhilProcarioJr
@kevinwatts
Here is how to fix the other case.
Phil Procario Jr.
Message 7 of 13
HughesTooling
Hey Phil, there's an easier way for your last example. Stay in the model workspace, select the 2 faces that form the D and delete., in the model workspace it will auto heal.
Mark
Mark Hughes
Message 8 of 13
PhilProcarioJr
@HughesTooling
I do use that method sometimes, but it depends on the complexity of the model as I have had that fail if the model is real complex.
Thanks for the heads up though.
Phil Procario Jr.
Message 9 of 13
kevinwatts
I have tried several of the methods sugested. The inner cavity/void is a complex shape.
In the Model Workspace, the Create Menu --> Boundary Fill method allows me to create a solid body of the inner cavity/void. It will not allow me to Join the two when creating it. I am now looking at trying to join/merge the two bodies together to form one without inner gaps.
Message 10 of 13
I_Forge_KC
Did the MODIFY > COMBINE tool work?
K. Cornett
Generative Design Consultant / Trainer
Message 11 of 13
kevinwatts
I tried serveral of the sugestions and was able to fill the cavity/void within the housing! Smiley Happy
Boundary Fill
Staying in the Model Workspace and working with Components, the "KEY" to filling a void/cavity within a body is to make the component (or sub-component) Active. If you do not, you can not JOIN the new material with the body that you are trying to fill. Otherwise Boundary Fill will create a separate Body, which is great if you need a "mold" or "casting" of the inside of a part.
Here is a simple and clear video of the process. Just remember to make the Component active if you want to Join it together in to one body.
Use the boundary fill function – simple and good tutorial
https://www.youtube.com/watch?v=KB_yNaTDZcI
The other methods mentioned above by both Mark, James and Phil are alternative approaches. Which workspace you are in and the complexity of the interior surface will determine which method will work best for you. The interior cavity/void that I had to fill was complex.
I appreciate everyone's suggestions and help to get past this roadblock!
Kevin
Message 12 of 13
kevinwatts
Thank you for the suggestion Kenny.
In my last post I describe what worked for me. I had forgotten that the part I was trying to fill was a sub-component of a component. The Boundary Fill method worked well once I had the area defined. After I had to rename the body within the target sub-component as the program JOINS the two bodies (created and existing) and assigns a generic name.
Message 13 of 13
troygATJ4L
Just what I needed! Spent an entire day trying to figure this out!!  Thanks for shoving me in the right direction!  The video leaves out some important information but a commenter posted the solution there.
Awesome community!
