File Types for eDrawings
'You can open eDrawings files (*.eprt, *.easm, *.edrw), SOLIDWORKS files (*.sldprt, *.sldasm, *.slddrw) files and DXF/DWG files in eDrawings for iOS.' -http://www.edrawingsviewer.com/ed/11727_ENU_HTML.htm
My question is, is there anyway that I can convert my file type from fusion 360 (.stl etc) to a one above? If so how would I go about it?
Thanks.
innovatenate
Autodesk Support
Autodesk Support
All of the supported export file formats are outlined in the below link.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I don't believe there is a way to export a model into the SolidWorks format to view it in eDrawings.
Fusion 360 does offer the ability to view designs through a web browser though.
You can use the share public link command outlined in the below link to allow someone to view a design. If you enable the download link, the person who receives the link can download the file in one of the file formats outlined in the export link above.
https://knowledge.autodesk.com/support/a360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-sh...
You could also use the Fusion Live Review feature.
http://www.autodesk.com/products/fusion-360/blog/quick-tip-live-review/
I hope that helps.
Nathan Chandler
Principal Specialist
