file is not loading, no error
KirillChepizhko
KirillChepizhko
I have fusion installed on 2 machine. On my desktop my file shows up in the project but wil not load and will not open, no error message, just infinite loading and eventually crash exit . It opens fine on the laptop
innovatenate
Autodesk Support
Autodesk Support
I've sent you a PM directly with a suggestion. I hope it helps!
Nathan Chandler
Principal Specialist
AndyAutodesk3D
Observer
Observer
Hi, Can you post the solution?? I have the same problem and it's not very useful to see you've sent him the solution but nobody else can see it...
Andy
michaelJXKSZ
Observer
Observer
A logout and a new login in Fusion360 did it for me.
And now the projects are loaded properly again.
