File Icon for an imported file?
jb332699
jb332699
I have imported a file and it creates a body using an icon I have not seen before.  Can anyone tell me what this icon represents?  What type of body is it?  It is not the same icon for a body I see when using Form/SCULPT or MODEL?
Please see .pdf attachment
Thank-you
lucasliraAU
Hello!
This file is working with the manipulation of MESH recognized through the import of an .STL file You can return to Sculpture mode as follows:
I hope this answer can help with your work!
If this works, you can signal this issue as a solution! Thank you.
Greetings!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
jb332699
Thank-you Lucas - very helpful!
