File Crash when trying to edit or delete past features?
I am not sure this is the place for a question like this but here it is.
I have a more or less simple part that I made and simulated. I then needed to backtrack in the feature timeline and make some changes and resave as an updated part. After I simulated the part and went back to edit a feature (fillet) it crashed. I then reopened 360 and tried again with no success. It seems the file is corrupt from this particular fillet back in the timeline, I can edit things ahead of it but nothing behind it. I do not have an older version of the part to revert back to and there were no autosave files for a good version of the part.
Things I have tried:
-Deleting the fillet
-Editing the fillet
-Moving the time head behind the fillet (results in a crash)
-Restarting computer
-Logging out of 360
How can I fix this without having to redraw the part?
innovatenate
Autodesk Support
Autodesk Support
Is it possible to share the Fusion Design with me?
Feel free to PM me a share link if you prefer to keep the design private.
Nathan Chandler
Principal Specialist
I can not share the part but I have partially solved the issue. I opened the file on my mac (previously opened with pc) and it worked great so I deleted the problemed fillet and resaved it and now I  can open the file on my pc just fine. Although when I try and add the fillet again, it crashes... I think it is an issue with the fillet algorithm on some of the more complex shapes. For now I am doing my simulations with an un fillited part and then adding the fillets at the end for visuals since once I add the fillets, it corrupts the file.
innovatenate
Autodesk Support
Autodesk Support
Thank you for the update and for all of the information. This sounds eerily similar to a report I logged recently (ref ID FUS-25799). I wasn't able to verify via an error report. It doesn't appear that any have been submitted from your e-mail address. If possible, please submit the error reports to Autodesk. They can be a big help to identify and fix these types of issues.
If there is anyway for me to get a sample design that exhibits this issues from you,  please let me know. I will be happy to add a test case to the report to make sure we are fixing the issue.
Nathan Chandler
Unfortunately 360 hard crashes and doesnt give me the option of sending a report of the problem. The only option is to close the program, and upon startup there is no evidence that it crashed and no recovery file for it.
innovatenate
Autodesk Support
Autodesk Support
I wanted to let you know that we have narrowed in on the root cause of this issue. We have found this to be a Windows specific issue. If you have access to Mac, you can open the design, perform a modify > compute all and then save a new version of the design. This will resolve the issue. We are actively working on a fix for this issue. If you have any questions or if I can help with anything, please let me know. I am happy to help.
Nathan Chandler
