Hi! I have no fewer than 30 hours into this ridiculously simple project, yet I remain stuck. It's a floor vent cover/grate.
I thought that I had finally gotten it figure out (ignoring the absurd machine time), yet, when I pulled the trigger the bit hovered a quarter inch or so above the surface on the first cut. 12mm, I think the zeroed readout said. I manually zeroed ... twice. ... with paper.
I'd soooooo welcome any input!
Solved by Mpradip. Go to Solution.
Hi @todd.n.beaulieu ,
I did check the same and found that the setup origin is located at the bottom of the part and if you have set the Z zero on the top of the part in the Actual machine it might be the issue.
Your setup:
I change the setup:
Please check the same and let us know it this helps.
Wow. What a dumb mistake, huh? Thank you. That worked. I keep bouncing between vcarve and F360 as I'm getting into this. Lots to learn and strengths and weaknesses of each.
