Feature Request: option to exclude hidden entities when creating an STL of a component
JetForMe
JetForMe
I have some fairly complex models I made for machining, but I also want to make a 3D print. I'd like to make an STL that excludes some of the bodies and/or components. Just a checkbox in the Save STL dialog that says "Exclude hidden entities" would do.
A more useful feature would be to be able to suppress entities in the browser, much like toolpath operations can be suppressed.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
daxpatel45
For separate Stl file Printing, you will make individual STL files for 3D printing Check Image Below).
Your Suggestion is Good But it Might Not Possible for Separate Parts to make Single.STL Files.
Hope This answers your question and gives you a separate printing solution and uses glue of Fevikwick to joint them.
Save .STL file.Save .STL file.
