Feature Request - Data Panel Navigation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Can we look at improving the navigation in the data panel slightly please? If you have a project with lots of folders, it becomes more inconvenient to jump from one to another the bigger the folder gets.
I have a job that has 80 designs in it, and I've grouped them in separate folders (Pocket 01 to Pocket 80) as this is the way we'll manufacture it and invoice the parts separately. When I get to Pocket 45 or so, The pocket is no longer shown on the list of folders in the dropdown menu when navigating the data panel.
The only way I'm able to get to this folder is to go up a level, then scroll down to the right folder, but you can't go up a folder level with one button click. You need to hover over the "...", then scroll down to the subfolder you want.
Would it be possible to add something like the "Up to Previous Folder" button in the Windows Explorer? It would just make the process a touch smoother and more robust feeling.
Thanks.
UPDATE: With the latest version of Fusion, when backing out of the folder, the data panel scrolls to the location of the current folder, which while not exactly what I was after, is a perfect solution for the issue I was facing.
