I've conducted an FEA simulation of a frame designed to connect to the rear of a bulldozer by 4 x 30mm diameter pins as shown in the image below. I have found the software very good, but am having trouble with the contact function and how it applies to the pins.
There is a 0.5mm clearance on diameter between the pins and the clevice and tongue holes. I think there should be three contact surfaces between each pin and surfaces on the clevice and tongues, but I am having trouble selecting these and knowing which contact type to use. At present I can't seem to get any loading on the pins at all. I have constrained the two tongues on both the vertical and horizontal sufaces.
It would be really good if someone could give me a demonstration of how to do this say for a simple rod end, pin, and clevice under tension?
Thanks in advance
