Hi @hariskhalil
I think the first step is to figure out what you are trying to analyze and make the model to suit the analysis. Perhaps you have done that already, but the model provided does not look like it is suitable for an analysis. Here's a simplified sketch of what I see in your Body1.f3d file:
- Item 1 is what I see in the actual model. Many of the diamonds are interfering with each other. Should they "magically" pass through each other?
- Should the model be like this? If so, how are the diamonds held together? Is it like a hinge and each diamond can rotate at the joint (as shown in the detail)? That is, they are not welded or glued or "melted" together. It is a "living hinge" and one diamond can flex/rotate relative to the adjacent diamond.
- Should the model be like this? The parts are continuous and welded or glued together (either as shown where the common faces can transmit the equivalent of a moment, or in the detail where the diamonds are all "melted" together).
The next question is how do one row of diamonds connect to the row underneath. In your model, most are just touching at a point where they touch. This will not transfer a load between rows in the analysis (or certainly not very accurately).
The diamond-shape bars cross at an angle. Therefore, the contact between 2 diamonds is a single point.
Next is the question about creating the model. If you cannot export the model as a STEP (.step or .stp), ACIS (.sat) or IGES (.iges or .igs), then you should create the model in Fusion.
If you have any other questions about the modeling, whether importing your model or creating it from scratch, I suggest that you create a new post. The text "FEA analysis" in the title of this post will limit the responses from the modeling experts that you want to participate in the conversation. In other words, the real problem is creating the model properly. The fact that you want to use it for an analysis is not important (at least not yet, not until you have the proper model and have question specific to the simulation).
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
