Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Failure to Generate Tool Path
1 REPLY 1
wadeanres
196 Views, 1 Reply
I have a VW Model that I cut in order to carve  CNC Model.  The model cut fine but I can't seem to get Fusion to generate a tool path.  I think the windows might be giving me trouble.  Any ideas on what might be giving me problems?  I posted the link to my Fusion project.
https://a360.co/33ThZyF
1 REPLY 1
Pradipio
in reply to: wadeanres
Hi @wadeanres ,
Thanks for Posting, the error seems that you does not have select the model in Setup.
kindly select the model from the setup > select the model. And recalculate the toolpath.
Also, related article for the same Issue Error: "model has missing selections" when generating a toolpath in Fusion 360 or HSM CAM
I hope this will helps to move ahead.
Please accept the solution if you get it done.
THANKS
Pradip Mistry
”Community
