Failed to Complete Generative Design Outcome
dhalpe.1855686
dhalpe.1855686
Dear Fusion 360 Team,
Generative design failed to generate a outcome. In the pre-check and pre-viewer command did not show any error.
Please advice find attached herewith is the file.
Hi, @dhalpe.1855686 ,
I checked your files but, by looking at those its not possible to tell error. Can you please attach screenshot of error being displayed.
Thank You.
dhalpe.1855686
Dear sbkariya99,
Thank you for checking files. The issue is that the outcomes are failing. I also tried with resolution set to coarse bu thte result failed for this case as well.
I have attached a photo.
Thank You
Hi @dhalpe.1855686 ,
There are two type of failures that we get one due to any technical error or something in which output is not being generated only.  You get some failure message on screen in red text that generally caused by technical glitch, cloud error etc.
But Perticular output getting failed can have multiple reasons depends on setup, some of resoans like;
Excesssive Obstacle geomentry
Unreaalistic load condition
Very less load
Material selection
Manufacturing Process selection
Starting shape
Resolution
As you mentioned about resolution you can try with other factors.
Thank You.
Sagar Kariya
