Failed to boolean bodies together/ cannot join
cantwell.akos
cantwell.akos
I am modelling this fuselage for 3d printing. I split this body earlier to edit the insides and now i cant rejoin it. Can someone help me out?
matt.oosthuizen
Hi @cantwell.akos
Please find attached the file with the combined body.
It seemed the two bodies were not overlapped, so I had to move the second body 0.001mm into the other, to create a slight overlap in the geometries and allow the combine tool to work.
Before you print this, I would have a look at the internal geometry again, there seems to be a few areas which could cause issues.
If you are happy with this solution, please press the accept solution button on this reply.
Good luck with your project!
Kind regards,
Matt Oosthuizen.
cantwell.akos
Thanks!
