face containment cannot be determined?
Sungod3000
Sungod3000
Im working and a relatively simple model here and I had it working before, but I seem to have made some changes that fusion doesnt like.
The two cogwheels are the same except for the letter on top. The idea is to make a 3d printable axis that keeps the cogwheels on the holding bar below. I have the pin modeled and then I join the part of the pin from the sketch with a
I have the pin already modeled and then I refine the shape of the pin with a simple "join revolve". Then I "cut revolve" a little bit more space of the wheel itself. The red wheel works fine but if I try to repeat the same revolve cut I get hit with: "face containment cannot be determined".
Can anyone explain that error?
Cheers
TheCADWhisperer
Try this one.
Sungod3000
Exactly! How do you do that?
JDMather
Turn on your sound...
