- Mute
- Permalink
- Report
New user here... I am trying to design a very simple cabinet with a face frame. My objective is to have a design that is adjustable based on the size needed and BOM cut list. Most YouTube videos do not address the frame style cabinet so my confusion centers around the use of bodies, components and assemblies when building the frame.
First, i have created user parameters for every possible piece of wood i would need to cut. Second, the basic construction is 2 sides, a back and a top, 4 pieces derived from the user parameters. I assuming they should each be a separate component. The confusion is in constructing the front frame. It consists of a top, bottom, left and right side. Their dimensions are also driven by parameters. Those pieces need to be components because bodies do not show up in a BOM. Should there be one component for each piece? How do you group the components? Should they stand alone? should they be sub components under a master component? Should they be grouped together under a an assembly? If i decide to design a second frame for the cabinet, would those pieces appear under a second assembly?
Thanks for any help
