Thanks for the input, everyone. Interesting theory about the update to ntdll.dll as being part of the problem. I'm not aware of any pattern of an update to this DLL causing crashes, but it is certainly possible. Have you been sending in crash reports? If so, I can take a look and see if there is any pattern to the crashes that you've been experiencing, but I have to be on the Autodesk network to do that - it may be till tomorrow till I get a chance to do that.
Also, a question: Have your recent crashes been with a variety of models, or mostly with one model. If there is a Fusion bug that a particular model reveals, and you spend a lot of time working with that model, then it can seem like Fusion is crashing more frequently than it used to. I've experienced that myself.
Finally, regarding letting Fusion run for long periods of time: I tend to let Fusion run for a while (like all weekend), but I have trained myself to shut it down before I put the computer to sleep, mostly because of the problems that @TrippyLighting refers to where Fusion used to crash a lot on wakeup if it was running when you put the computer to sleep. It should not be necessary - that bug has been fixed (we hope!), but now that I've gotten used to doing that I just do it out of habit. I also shut down Outlook before I put the machine to sleep, also because of some bad experiences in the past, FWIW...
Jeff
Jeff Strater
Engineering Director
