F360 repeat crashes when dimensioning drawing
rklopp
rklopp
AcCoreConsole runs to 100% CPU and the cursor disappears when I start dimensioning a simple drawing I made from a model. I think this is the first time I've used drawings since the latest update. This is on a MacBook Air with 8 gigs.
Could be a bug. If it completely crashes, make sure to file the crash reports to the Dev team. Have you run a Compute All on your model, just to check if there are no issues with the geometry you are creating a drawing of? You can run it with the shortcut Cmd+B (Mac) Ctrl+B (Windows).
NIels
cmiller66
Hi rklopp,
Thanks for reporting this.  Would it be possible for you to Export that design: File menu > Export > Archive file type (f3d) and email it to me a christopher dot miller@autodesk.com?
Looking at the image it is probably the modeled threads causing the issue.  We've fixed a problem like this before, it's possible it's returned.  In the meantime I'll try to repro here, but verifying the problem with the same design would be ideal.
Also, if you could try similar steps in a design without modeled threads and see if the problem happens there too and let me know, that would be appreciated.
Chris
