F360 Rectangle
F360 Rectangle
akkanein
F360 Rectangle
akkanein
Hello! I'm newbie in F360 and i need help. I trying make this Picture or this rectangle with more edges / faces. But i dont know how i can make it. Can you help? If you want this is link for full Travel Adapter Behance .
Oceanconcepts
It would help if you could be more specific about what you are having trouble with, or post a screenshot of what you have done. Sketching and extruding a rectangle would give you the basic shape, if you are asking how to get the grooves on the sides there could be multiple ways. You could create the basic shape of the groove as a solid, do a repeating pattern, and then subtract (Combine with cut option) to remove material.
Going through the basic modeling tutorials should help you to figure out how to make shapes like this.
- Ron
Mostly Mac- currently M1 MacBook Pro
akkanein
Ach sorry. I have basic shape and now i'm trying make grooves. I'm readed your answer and try make it.
chrisplyler
The easy way is to Extrude/Cut one groove, and then Pattern-on-a-Path all the way around. But the spacing changes at the corners for some reason.
