Hi all,
Was recently using the active component visibility option on and off to more easily see the objects I'm referencing in a new component and was hoping there may be an easier way to enable/disable this option? I think it would have been useful to be able to quickly turn this setting on and off to see what is active and what is not with for example a quick keyboard shortcut. Let me know if this exists and if not, can I turn this into a feature request?
Justin
as far as I am aware, there is no way to bind a shortcut to this command. Today, shortcuts are mostly limited to commands in the toolbar, and this command does not have a toolbar representation. The enhancement request is noted, thanks for sharing it with us.
A keyboard shortcut does not exist to toggle the setting you desire. You may want to try Isolate/Unisolate and see if it helps.
John Hackney, Retired
Thanks for the quick replies, @jeff_strater & @jhackney1972
Didn't think it was possible, but thought I'd through it out there and see if it was and or if anyone else was interested. And thanks @jhackney1972 for the tip about isolation, I do already use that feature, but it doesn't quite fit what I'm looking for exactly. Either way, not a big deal, but maybe a feature we'll see one day, thanks!
