Hey, I am tried to learn how to draw 3D of my model that has transition expansion of rectangular channels through S-Curve. The 2D drawing shows a hump within the transition zone, with the max height of hump crest at the outlet of transition. I draw the base of the model but find difficulties on extruding the base to build the 3D sections.
As a beginner, I cannot find any video that closes to my model in order to find the solution.
file link: https://a360.co/2TlXy78
without hump link: https://a360.co/2F3taLP
The 2D drawing in attachment
Thanks for help
Thanks for help
Solved by davebYYPCU. Go to Solution.
The removeable floor is two sketches and 2 extrudes.
Extrude the section sketch, wider than needed
Then extrude top view sketch, and set Operation type to Intersect.
Might help.....
Might help.....
Hello DavebYYPCU,
I appreciate your help on the above subject. As a beginner in Fusion 360, am still learning while working in my project.
I followed the steps mentioned in your message until I have reached the last step: extrude top view sketch and set Operation type to Intersect.
That didn't work to cut the extra areas outside the inner face of the channel.
Share file:
Is it possible to look at the drawing to find the problem?
Once again I appreciate your help
Mustafa
Hello DavebYYPCU,
Share file:
Mustafa
Sorry, somehow AD and my Internet provider, files downloaded from there do not come here.
If you Export the file you can attach to this system, I can read those.
Are you sure the first extrude does go past the top view sketch? Like this,
There must be overlap, for the Intersect Extrude to work.
Sent a PM, and here is my file to check, how.
To: davebYYPCU
Thanks a lot, it works now and I am able to complete the model.
I appreciate your support and assistance.
To: davebYYPCU
Ok, Sweet.
