Extruding in multiple directions at once
After quite a bit of googling I can't get the extrude tool to work the way I am used to in other 3D apps. I expect this is because I am trying to use fusion the wrong way, but can anyone tell me if the process illustrated in the attached image is even possible in fusion?
THanks
etfrench
Here's just one of many different ways to create that shape:
Note: You can change any of the dimensions using the Change Parameters dialog.
ETFrench
