Extruding and joining to a curved surface
andygrigg
andygrigg
Hi all,
I'm trying to extrude the highlighed surface up to meet the two tubes above, but I want it to create a blind hole with those surfaces. It's kind of the inverse of an intersection. I just want the extrusion to conform to the external surface profile of the two tubes so that it only acts as a support for the tubes above. Can anyone advise please?
Replies (7)
g-andresen
please share the file for reply
File > export > save as f3d on local drive >attach to post
günther
wersy
This should go with extrusion "To Object"
If needed with "Taper Angle".
andygrigg
Ahah, great. Thanks! Alas, it doesn't work for this specific model as it throws an error that the "Extrusion profile falls outside the boundary of the selected body". I think this will work if I split the bottom cylinder in half and extrude the two sides inidividually. Thanks for your help.
wersy
Right, I hadn't thought of that, an extrusion only works on one surface.
The profile to be extruded must be split.
andygrigg
Actually, that didn't work either. I did a workaround. Extrude all the way inside the tubes above and then use the tubes as the tool to split the body of the newly extruded part, and remove the excess.
TheCADWhisperer
@andygrigg
You should no t start with tubes.
Model solid and then use Shell feature to get the tubes.
Are your sketches fully defined?
jeff_strater
That is not entirely true.  To Object only works on a single body, but you can extrude to multiple faces on that body by selecting the body, not a single face.  I can't tell if the original model is one body or not, but if so, you should be able to make it work, providing the profile does cleanly intersect the body (the other source of this error is if the profile is too large, and does not intersect the body)
Jeff Strater
Engineering Director
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
