extrude - what happened
Extrude no longer seems to work like it previously worked. Going into a solid it cuts. Going away from a surface it extrudes a solid. going from one plane through a solid it cuts and I can no longer make it join, worse yet I don't have a choice.  What has happened?  If this is a new feature, I don't want it.
masa.minohara
Hi @Anonymous,
Thank you for posting this! I am not very sure what issue you are experiencing but would you be able to attach some screenshots for me here? Screencast and a public link to the design would be more helpful for me to better understand the issue.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
jeff_strater
There have not been any recent changes to Extrude.  This feature works the same as it always has, as far as I know.  As Masa says, a video would help.
Extrude does auto-select the operation.  If the Extrude intersects a solid, it will default to Cut.  If not, it will default to Join/New Body.  But, at any time, you can change this by changing the "Operation" setting in the tool.  Here is a screencast:
Jeff
Jeff Strater
Engineering Director
