Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Extrude to Object. Multiple Bodies
4 REPLIES 4
kfschmid
315 Views, 4 Replies
I would like to extrude a profile to the intersection of two other bodies.  I would like this extrude to be a new third body. I would like the extant of the third body to be the faces of the other two bodies.  In the example I drew up for the screenshots, Fusion is only allowing me to select one of the original bodies.  I do not want to merge the original two bodies into one.
Karl Schmidt
Tags (3)
4 REPLIES 4
etfrench
in reply to: kfschmid
Simply use the Split Body command to trim the excess, then either turn off the visibility of the excess or Remove it.
ETFrench
kfschmid
in reply to: etfrench
Etfrench,
I was hoping to avoid the extra steps of splitting and removing.  That is going to add a lot to the work flow.  I was hoping I was just not understanding how to use the to object extant properly.
Karl Schmidt
davebYYPCU
Not if you set up the Extrude from the side. Front as looking at the pic.
Might help....
etfrench
Yes, I can see where adding 15 seconds per extrude onto the workflow would add a lot.
ETFrench
Technology Administrators
