Extrude ShortCut differences in Patch Mode
In the Patch Mode, pressing the shortcut "e" will bring up an Extrude Command Box but it does not extrude the curve. That is screen shot1. But using the Search Box Shortcut "s" and searching for "e" will bring up an Extrude command box that is the same as selecting the Extrude from the drop down menu. This Extrude Command can Extrude the curve projected to a surface. That is screen shots 2 and 3. So can you either improve the short cuts so they can match up the different modes or cancel the Shortcut "e" in the Patch Mode?
1 Pressing short cut "e" brings up this Extrude Command Box that does not extrude the curve on the surface.
2 Pressing "s" and searching for "e" brings up a different Extrude command box, which is the same as selecting "Extrude" from drop down menu. This Extrude can extrude the curve projected to the surface from another curve above this solid plane:
3 The finished Illustration
Thanks!
Phil.E
luvmesweet,
Thank you for this excellent report. Your text and images helped greatly to investigate and get this bug reported. I'm sure it will help the developer to be able to refer to this report. Well done!
The internal report number is FUS-21157.
Best regards,
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Dear Phil, thanks!
