extrude problem
extrude problem
extrude problem
Since the last update i'm not possible to select multiple surfaces to extrude.
I'm running on mac os "el captain" and all updates for fusion are in.
Hope you can give me a hand
thx
greetz Bens from Belgium
HughesTooling
Try holding the Command key down to add to the first selection.
Mark
Mark Hughes
Owner, Hughes Tooling
Already tried that, stays the same
thx or the reply
HughesTooling
Are all the sketches\surfaces on the same plane? can you attach a screen grab and or an f3d you're working with.
Mark
Mark Hughes
dsouzasujay
Hi @Anonymous,
I am able to select and extrude multiple surfaces.
Can you please share the model.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
