circular hole pattern
Circular pattern,
cirpattern only shows up when I run my cursur over the hole. I checked the light bulbs and I turned all on, and all I saw was the original hole. the other 5 only show  when I run the curser over it.
TheCADWhisperer
Do you see the edges when you go to wireframe display mode?
Can you File>Export and attach the *.f3d file here?
Here they are.  in the other views I can see it
Beyondforce
Hi @Anonymous,
In the screencast, I will show you why it didn't work as you wanted:
Please let us know if you have more questions.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Thank you so much
