Extract a single face from solid body
rajugupta050605
rajugupta050605
Hii
I want to extract a single face from a solid body, I didn't find any command like Extract face in "Fusion 360".
I tried to use Unstitch command in surface workspace, but i am facing problem is the whole body will be converting into the sheet body but i want only the selected surfaces and the body will remains same.
Is there any option available in Fusion 360 for extracting only selected surfaces from solid.
I attached a small animated gif file of my workflow.
Please share is there any option like Extract face or is their any better workflow for this problem.
g-andresen
what do you want to achieve?
Please share the file for reply
File > export > save as f3d on local drive  > attach to post.
günther
SaeedHamza
Just select the face and choose Offset Face with the distance input being 0.
Saeed Hamza
rajugupta050605
Thanks for the help problem solved.
