Exporting STL ignores imported STL mesh
davide.toldo
Message 1 of 11
davide.toldo
Hello everyone,
I tried for hours now to export my finished model and whatever I do, a part of my model (that is an imported STL) just gets ignored by Fusion 360!
I found one video on youtube where someone uses an Autodesk program for converting STL using REMAKE which unfortunately is not available for Mac anymore.......
So how can I finally get my full model without half of it missing??
Thank you in advance!
Replies (10)
Message 2 of 11
etfrench
How big is the STL? If it's less than 50,000 (IIRC) facets then you should be able to convert it to a BRep.
How did you import the STL? Is it linked to the original file?
What file format are you exporting?
FWIW, I'm not having any trouble importing an STL as a mesh then exporting as an archive file or as another STL.
ETFrench
Message 3 of 11
davide.toldo
Where can I see the size? It is actually pretty big. I do not have an option for converting to BRep.
Message 4 of 11
etfrench
Right click on the mesh body in the Browser.  Select Properties.
  1. You need to be in Direct Modeling mode in order to convert to BRep.
  2. Import the STL into a new file.
  3. Click on the top node in the Browser.
  4. Click on "Do not capture Design history".  This will put you in Direct Modeling mode.
You should now have an option to convert to BRep.  If the conversion is successful, copy the BRep component into your main file.
ETFrench
Message 5 of 11
davide.toldo
Thank you! It's somewhere around 36k facets.
Adding it to a new file and disabling the design history shows the option of BRep conversion. I started it but it seems to take several minutes.
Let's see.
Message 6 of 11
etfrench
If you are trying to export as an STL, then the imported STL must be a subcomponent of the component to be exported. If you want the entire file exported, then selecting the top node in the Browser will allow you to do this, otherwise you'll need to organize the model so all of the components to be exported are subcomponents of the same parent.  If you are attempting to export bodies, see Rule #1.
ETFrench
Message 7 of 11
davide.toldo
I want to export everything except one thing that is hidden (with the light bulb).
I'll try the selecting-top-node method 🙂
Message 8 of 11
HughesTooling
Try using the online dashboard, https://myhub.autodesk360.com/g/all_projects/active
Make sure you've saved the design with only the parts you want in the stl visible. Open the part in the online viewer then request an stl file as the download.
Mark Hughes
Owner, Hughes Tooling
Message 9 of 11
davide.toldo
perfect, thank you very much!
Message 10 of 11
Thanks for posting this - it worked! All I can say is that thus far Fusion 360 has been painfully unintuitive and horrible to use. Workarounds like this shouldn't be necessary for basic functions.
Message 11 of 11
dmitriy
This is a really silly solution - the software should have this capacity, not a bandaid like this.
FusionTeam - this should be properly addressed!
