Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all - I'm having trouble with exporting a sketch to DXF. The part is very simple - a box rectangle, extruded to 0.25". When I Save as DXF, the resulting geometry is as expected. I then edited that sketch and added 10mm fillets to the corners. The extruded model in Fusion looks as expected, and the sketch is fully defined. When I Save as DXF with the fillets, the resulting geometry is wrong - I basically get an oval with a small bump on it. Any ideas? Thank you for any help you can provide!
Sketch in Fusion:
Resulting DXF:
