Exporting Simulation Mesh and Results from Fusion
mcmillr
Alumni Alumni
Message 1 of 33
mcmillr
We have implemented a very basic capability to export the Simulation Mesh and Results from Fusion to VTU format. This format can be viewed in tools such as Paraview.
When you are in a Simulation study and you have results displayed, you can type the following command to export the active result plot:
SimResults.ExportActiveResults d:\my_sim.vtu
You can of course use any path or file name you want.
If you open this in Paraview you can press Apply and it should render the mesh and results.
If you only want the mesh data, you can use this command:
SimMeshDB.Export  0  d:\my_mesh.vtu
This should be useful for anyone who would like to implement a custom analysis or rendering that Fusion Sim cannot do. In the future we may move this from the command line to a full fledged UI.
Rob McMillan
Software Architect, Fusion Simulation
Replies (32)
Message 21 of 33
John_Holtz
Autodesk Support
Autodesk Support
Hi @charlesmarvic.quito
You did not answer either of my two questions. Before I ask even more questions, please create a screen capture of the full Fusion 360 window that shows the following items:
  1. The displacement results color contour.
  2. The browser window showing the study name (hopefully it has the default text that shows the study type, like "Study 1 - Static Stress"), loads and constraints.
  3. The text command window showing the command that you are entering and response after you press Enter.
Thank you.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Message 22 of 33
mmilleratticus
Hi John,
Does this mean a person can export the results to Paraview, Export from Paraview as a "printable solid" and 3D print a prediction?
I tried the Paraview option a while back with limited results.  Unfortunately at that time the results did not include being able to 3D print the software predicted results.
Clear skies,
Matt
Best regards,
Matt
Message 23 of 33
l.chabin
Can I import a vtu file into a Fusion 360 Design workspace ?
Message 24 of 33
mmilleratticus
I'm not sure if the file can be imported.  John Holtz gave instruction on exporting VTU files into paraview.   If you can find where the file is being stored you might be able to replace it and see if it work?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Message 25 of 33
mcmillr
No, there is no way to import vtu data into Fusion, sorry.
Rob McMillan
Message 26 of 33
hamid.sh.
@l.chabin @mmilleratticus @mcmillr  I have imported result of simulation (deformed body) back to Fusion's design workspace as a mesh. Check my reply to this post.
Hamid
Message 27 of 33
TrippyLighting
@hamid.sh. super cool stuff! This has only come up 2-3 times in the time I've been on this forum.
Message 28 of 33
mmilleratticus
Printing predictions has been around for a long time in the industry.  I cannot imagine the cool things all the clever people who use Fusion 360 will cook up when they finally add this funtionality.
I was doing it in 2005 with this sofware: https://www.deform.com/
Message 29 of 33
l.chabin
Yes, I am interested in the details to your method.
Especially, I couldn't find the commands to export only X,Y,Z disp. in separate files.
You can post in the thread https://forums.autodesk.com/t5/fusion-360-support/can-fusion-360-simulate-a-bend-when-2-components-a...
Message 30 of 33
hamid.sh.
@TrippyLighting Yes it is cool! I haven't been here for long, but the post under which I described the method turned my curiosity on, searched and found out about export being possible via text commands, so I wanted to see if I can get the mesh back to Fusion.
Here is a an example in which I virtually pressed an embossed aluminum sheet against a steel mold and got the deformed mesh back in design workspace (and converted it into BRep but needed some edit...):
Obviously not a good modeling practice (you know, mesh conversion...) but I can imagine cases that this will come in handy.
Hamid
Message 31 of 33
DimitriNL
Observer
Observer
Hi all,
I have been trying for some time to do the following.
I want to use the simulation visuals (i.e. the Von Mises color map) in the animation environment. Back in the days when I was working in a local Autodesk retailer, I used different software for simulation (Mechanical) which had a feature ''export to showcase'' and then I used showcase to make rendered images and animations with the stresses shown in the parts, zoom into details etc. I have exported the vtu files from fusion, but from my understanding the colormap cannot be imported. Is that correct?
Thanks all,
Dimitri
Message 32 of 33
mcmillr
Hi Dimitri. You are correct, the color map cannot be imported back to Fusion.
Sorry I don't have a better answer for you.
Rob McMillan
Message 33 of 33
John_Holtz
Autodesk Support
Autodesk Support
@mcmillr  I thought @DimitriNL was asking if the VTU file exported from Fusion will include the von Mises results so that he can create animations in Paraview. My understanding is whatever result is shown when you create the VTU file in Fusion (whether it is stress, displacement, etc) will be included in the VTU file; therefore, Paraview should show that result.
Both of you can correct me if my understanding is wrong. 🙂
John
John Holtz, P.E.
Autodesk, Inc.
