Exporting model from Fusion 360 to revit. How to do it?
I have main model created in houdini
Model was saved out as OBJ file.
OBJ file was loaded in to Fusion 360
I used "right click on model" selected "mesh to brep"
This created now my model as separate parts. (all elements are separate).
But how to save it now out and send it to revit?
Because when i select "File" and "export"
i get only file formats like
1.  Archive Files - *.f3d
2. IGES Files - *.igs and *.iges
2. SAT Files - *.sat
SMT Files - *.smt
STEP Files - *stp and *.step
I tried to export as sat file and tried to load model in to revit via "Insert" and "Import CAD"
But nothing happened in revit. I do not see my model.
kirils
same question here, what is the workflow from fusion to revit?
algor_neil
What can Revit import ?
HughesTooling
Thought Revit could import SAT files, is it because you started with a mesh that's the problem? Have you tried a simple test like create a cube in Fusion and export to SAT?
Another option is go to your hub and export from there as a DWG, you might need to delete the mesh from the design first.
Mark
Mark Hughes
Owner, Hughes Tooling
