Exporting IGS not IGES
janUUXRT
janUUXRT
I have a problem with exporting igs files.
My CNC machine only support .igs and don't see .iges
Is there a way to export straight .igs file ?
TheCADWhisperer
What happens if you rename the extension?
janUUXRT
Files sometimes works, sometimes not.
But works always works if I import them to Solidworks (IGES) and export from there to IGS.
Maybe there is a way to change export settings in Fusion?
I'm importing files to nesting software for 3D laser cutting.
TrippyLighting
.igs and .iges are the same thing. .igs dates back to times when Windows operating systems only accepted 3-letter file extensions.
TheCADWhisperer
@janUUXRT wrote:
…sometimes not.
@janUUXRT
That is the file that you should have Attached here.
