exporting components
ronnierozier2_Mississippi
1.088Aufrufe
6Antworten
Nachricht 1 von 7
Hello all,
Creating assemblies is a new skill im trying to learn and would like some help please. What I would like to do is basically take all my components and export them as DXF files so i can use another software package to nest and cut on my CNC.
If it is possible to do lay out flat, nest(either automatically or manually), then cut in fusion that would make it even better !! I love fusion 360 CAM !!
- - - attached is my first assembly- - -
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (2)
1.089Aufrufe
6Antworten
Antworten (6)
Nachricht 2 von 7
Nicht anwendbar
There is some plugin called NESTER
and this video from Lars can help
https://www.youtube.com/watch?v=Ji69CGAIZqQ
Nachricht 3 von 7
Thanks I will check it out shortly...
Nachricht 4 von 7
davebYYPCU
Akzeptierte Lösung
You are mixing terms and procedures, I don't use Fusion CAM,
but have experience with CNC mills, lathes but more recently with Laser cutting, and 3d printing.
You like Fusion CAM, but asked for dxf files for other software, you can do both.
Both are wildly differently workflows.
Dxf files, are sketch / body outline exports.
CAM in Fusion can use either sketches or 3d models.
I use the Addin called DXFer, from GitHub to take the face of your body/s, multiples are ok, and collect them all in a dxf file, to export.
Nesting routines have not been developed, yet.
Might help...
Nachricht 5 von 7
I just installed DXFer and I must say it does exactly what I am wanting to do.
Nachricht 6 von 7
where do i find this plugin ??
Nachricht 7 von 7
davebYYPCU
Akzeptierte Lösung
Nester is also in GitHub, by the same author,
I used it before he developed DXFer,
Nester does linear nesting, needs components, and worked fine.
I don't need to construct the components in my work, so the DXFer is a better fit for me.
Might help...
