Exporting as an fd3 NOT fdz
Drewpan
Advisor Advisor
Drewpan
Hi All,
It seems that we have gone back to being limited to exporting fdz files again.
Has anyone else noticed this? Devs, can we PLEASE have the ability to export
fd3 files AGAIN because it makes it much easier to both post to the forum and
also send to others. Sending to others is painful as you need to explain to them
to unzip the file first. I understand the need for archived versions but small
files simply do not require it. This should be a simple "turn it back on" fix.
Cheers
Andrew
davebYYPCU
F3d and or F3z files are attachable to the forum.
F3d files are strictly independent of any external file/data.
F3z has external references within it.
I have not seen any problem exporting F3d, because I don't use drawings, external components, or configurations, all of which will automatically trigger the F3z file format.
Might help...
a.laasW8M6T
Hi
I don't believe anything has changed here
Are you aware of the Conditions the cause a file to be an .f3z?
Simply Put if there are ANY external references(Linked components, Fasteners, Derived Components, Machines(That have a Machine Model) then the File will be exported as an .f3z
If you don't want it to be an .f3z then you must break any links to external components etc
Andrew Laas
Senior Machinist, Scott Automation
Drewpan
Ok. So the imported STL file is causing this? The file is still very small. I should have the option.
Cheers
Andrew
a.laasW8M6T
Hi
It has nothing to do with file size.
Inserting a Mesh should not create any external references, there must be something else going on
Andrew Laas
davebYYPCU
We will need a screenshot of your expanded browser content.
Warmingup1953
Please share your Fusion file, even if it is a .f3z.
I imagine you are uploading the .stl to your Fusion Cloud Data panel, then dragging it into your design file?
Attached are two approaches: one is the uploading then dragging method which necessitates the .f3z...
The other is Insert from desktop as a mesh that allows export as your desired .f3d
