Export to SVG (free version)
VGBenjamin
VGBenjamin
I would like to export my design to cut it with my laser in lightburn so the svg format would be great to do it.
I have first find the plugin NESTER but I have two issues with it:
- It split my box but the material panel is on the Z axe and with the joins I can't rotate it.
- Even if I have it split how can I export to svg from here?
Then I have also found the Shaper Utilities but there I need to export component per component so not really easy because when I expert everything at once I have something like this as it keep the positions of my bodies (I think):
I have the free version so if I am correct I cannot use the arrange feature in the manufacture model option as it is disabled.
My example is in attach.
Replies (9)
davebYYPCU
Create an output sketch, select and Project > Project the faces of all your bodies, into this sketch.
When exporting, I don’t think sketches can be exported to SVG, but you can export sketch to dxf.
Dxf files should be compatible with Lightburn, but I am not sure of that.
Might help….
HughesTooling
The Shaper add in will export to SVG.
Mark Hughes
Owner, Hughes Tooling
VGBenjamin
Thank you but as I explained I didn't succeed to use the Shaper Add in well as I need to export face per face so not very handy and when I export everything at once the shape is incorrect.
If I first apply the NESTER plugin and then the Shaper one then I have the following result (probably because my panel is oriented on the Z axe)
VGBenjamin
Thank you for your suggestion
@davebYYPCU  .
When I try to create the sketch after using the nester plugin, I have a message that ask if I want to capture the poistion but even if I say yes, all my component are on top of each other.  How could I fix this issue?
Before:
Capture message (in french sorry):
When I click on capture position:
HughesTooling
Do you have access to the arrange feature in the design workspace with the free licence?
Mark Hughes
VGBenjamin
I have the same preference screen as you do but I don't think that I have the option available in the designer.
Warmingup1953
Why not Export .dxf and use that file as the import in Lightburn? The scale will be less of a gamble and guess as well!
HughesTooling
If you have the arrange option checked in preferences you should see them under modify.
Mark Hughes
VGBenjamin
No it is grayed out :
