Export to Bambu Labs issues
neptune06p2v_eaa
neptune06p2v_eaa
Greetings,
I made a very nice and very complex design in Fusion 360 using student edition. I tried to export the model to Bambu Studio using the "Save as mesh" option with high refinement quality. When I import the .3MF file into Bambu Studio, the main structure is accurate, but the text that I embedded into the object via the extrude function is blown out of proportion and misplaced. I do not know how to fix this. Please help!!
TrippyLighting
Can you share your fusion design?
If so, please export it as a .f3d (or.f3z) file and attach it to a post.
Drewpan
I do have a bit of experience with many Slicers, including Bambu and Bambu
Studio slicer. I have found recently that Fusion does not always get a good
translation file directly into 3mf. Not sure why as Fusion claims it is supported.
In my recent experience I have simply exported as a Mesh and selected ASCII
STL as my file type. Bambu recognises this and imports it without any issues
I have had so far. I have been working on a Ducted Fan with some very complex
geometry and get good prints using this method. I also do a Save As Mesh
directly on the Component and NOT use the Export Command.
Try it out and see if I makes a difference.
Cheers
Andrew
TrippyLighting
@neptune06p2v_eaa @Drewpan , if you are experiencing problems, please share your Fusion files, your workflow, and what you want to accomplish.  I'd be happy to look at it and/or tag an Autodesk employee to look into it.
neptune06p2v_eaa
Hello friends, thank you for your response! I was able to get the issue figured out. I needed to extrude the logo a little more and I needed to export the overall model as a STEP, not a STL. Finally, I used the "Fix Model" tool in Bambu Studio to fix the broken aspects of the model.
Many thanks for your assistance! Have a great day!
