Export Model in SVG/DXF
I am interested with exporting my model in SVG for lasercutting.
On the right of the attached picture is an exemple of model I did using sketchup, but I haven't succeed yet with fusion to export as needed.
Exporting using the DXF function on every sketches doesn't suit because it won't take in consideration some cut & extrusions done afterwards.
Any thoughts ?
Guillaume
MRWakefield
If I understand your post correctly I expect you'll want to create drawings of each of the components you want to laser cut and export each of these drawings as DXF.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
g-andresen
SVG export does not exist in Fusion.
But you can project the complete body contours into a sketch to capture all elements including those that are not sketch-based.
günther
