EXPORT IGES problem
EXPORT IGES problem
matej.biro
EXPORT IGES problem
matej.biro
Hello, i need to send IGES model to customer for simulations. When i exported and sent they had ERROR message: " IGES solid entities are not supported, the result of translation maybe incorrect. Please export your data using surfaces option.
They said that i have to export it as "trimmed surfaces" and not as solid entities roboguide.
Can you help me with it?
innovatenate
Autodesk Support
Autodesk Support
You could send the customer a share link to the design and let them try a couple of different file formats.
https://knowledge.autodesk.com/support/a360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-sh...
There are no export options for Fusion 360.  If you have a solid BREP body and export to IGES, you should be able to read the solid body in the target application.
With that said, maybe it would be easier to try a STEP , or different file format. Do you know what application the IGES file is being imported into?
Nathan Chandler
Principal Specialist
matej.biro
Its program for robot simulation and it only support IGES
HughesTooling
You could try switching to the patch workspace and unstitch the model before exporting.
Mark
Mark Hughes
Owner, Hughes Tooling
matej.biro
I solved it through other CAD software , exported as STEP - open and export as IGES, i hope it will work.
Thank you.
