Export from TinkerCAD to Fusion360
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Fusion360 forum,
Have worked in TinkerCAD for years but as the models became more complex TinkerCAD seemed to struggle to keep up, took an inordinately long time to render and failed returning messages like 'Node fails to load.'
So after some research (SolidWorks and Blender) a transition was made to F360. But I have years of work in TinkerCAD the results of which should be brought into F360.
I tried the Insert Mesh method which is ok for flat planes but is most difficult for even the simplest round shapes.
Tried the Send To feature in TinkerCAD sending this shape:
When the part was imported into F360 this is the result:
Have tried as exporting to Microsoft 3D Builder and back into TinkerCAD before using Send To in TinkerCAD. (By the way, exporting TinkeCAD into Microsoft 3D Builder, renaming the part, and then importing back inro TinkerCAD is a way to get of all of the history that TinkerCAD is keeping which slows down and sometimes prevents rendering.) Tried exporting as STL and OBJ files and then reimporting into TinkerCAD. Have tried other objects and when it imports into F360 it imports parts of the shape only.
So a simpler shape was tried
In TinkerCAD at Send To > Send to Fusion360 the software returns ' No compatible objects were selected for Fusion'
Is the TinkerCAD to Fusion360 Send To function defective or am I missing something?
Thanks.
Allen Pitts, Dallas TX
