Export driven-dimension-values to csv file
i wonder if its possible to export the values of driven dimensions... Is that what is meant with referencing?
I don't need to manipulate them... just need their values. ... so if there is any option to do this instead copying everything by hand like a monk...
HughesTooling
Does this help?
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1801418194626000805&appLang=en&os=Win64
Mark Hughes
Owner, Hughes Tooling
unfortunately not... driven measurements do not appear as parameters the suggested app then could export... so its the Change Parameters that should list them in the first place. There is a feature request pending for several years now... But hey, i'm using the software for free so i won't ask my money back.
markER7TS
You can output driven dimensions from a sketch with code like this...
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        f = open('P:\dd.csv', 'w')
        root = des.rootComponent
        ske = root.sketches.itemByName('Sketch1')
        for skd in ske.sketchDimensions:
            prm = skd.parameter
            f.write(prm.name + ',' + str(prm.value) + '\n')
        f.close()
        ui.messageBox('end run ***')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
So this is possible, just not super user friendly.
Mark
