Export drawing as dxf to zero plane
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
All,
When exporting a drawing as dxf the file doesn’t move all the geometry to the same (zero) plane. If a line is in 3-dimensional space in Fusion, the line remains in 3-dimensional space in the dxf file. The resulting file in my cnc software is unusable since the geometry isn’t flattened to the same plane.
I’ve tried opening the dxf file back into Fusion and editing the sketch, move the geometry to sketch plane, then write out the sketch as a dxf. This works unless there are tangent edges, those tangent edges aren’t selectable to move to the sketch plane. You can project the tangent edges to the sketch, but if there are a lot of them that’s pretty time consuming.
I’ve also tried QCad to flatten the dxf file, but when I opened the dxf file in QCad the part was “exploded”, with lines and arcs all over the place.
Drawing files written out of Inventor in dxf format come in “flattened” to the zero plane in 2D software.
Can someone please tell me if this issue is on the roadmap to address? Or is there another work around that I may be missing to get all the geometry to the same plane?
Thank you,
