Export/Backup entire project with all files
Natranzow
Natranzow
Any way to save an entire project and any files within the folders? IVe tried to export via browser but it looks like it just save the folder tree but contains no design files. I want to save EVERYTHING we have locally.
Pradipio
Autodesk Support
Autodesk Support
Hi @Natranzow ,
Thanks for posting to the Fusion 360 Forum.
I do understand your requirement but I am sorry there is no direct option to export the entire project at a time.
But you can try with the desktop connector, it will give you a Fusion 360 connector over there you can copy your files when required, and the files will be available in your system even when you are offline.
below is the image from my system of how it looks like.
On the left, the fusion 360 projects are open as Folder and right side Fusion 360 data panel.
Follow the link for the Desktop connector.
THANKS
Pradip Mistry
”Community
