export a module
export a module
eng.abass5
export a module
eng.abass5
if my file has more than one module and i just need to export
one module to use it in cfd, how can i make it ?
TheCADWhisperer
And please indicate which "module" you need exported and the type of file.
eng.abass5
Thank you bro , but i am looking for a simple way todo it always
By my self .
daniel_lyall
@eng.abass5 @TheCADWhisperer will be asking for your file so he can show you how to do it with the bit you wont to export from your file and to see if there is a mistake in it that can be a problem.
Most times when you have problems your model, pictures and a screencast of the problem plus a written explanation of the problem is needed other wise it's a guess and the reply may just be wrong.
PS you sound like a kiwi ??
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
eng.abass5
Ok , no problem ..
i will prepare my file and send upload it here , thanks a lot .
eng.abass5
Dear, i attached the file and the captured image for the module i need to export it.
 Also, i am wondering if i want to use this model in CFD and let water enter from one port and
exit from the other, shall i combine the bodies as one body.
